It is currently Thu Sep 18, 2025 12:23 pm
 Post subject: Help with cut strips
PostPosted: Sat Aug 28, 2021 5:33 pm
Hello! Im new member here! I'm interested in finding a way to easily cut strips (black and white) for the tonewood . The material is celluloid. How do you or someone else use them to cut them? Their width is 2 mm their thickness is 0.40 to 0.60 and 50-60 cm length. I'm looking to find a machine or my own construction that I can cut straight and right one from the other. Manual always. Any idea? Thank youfor the attention!!
 Post subject: Re: Help with cut strips
PostPosted: Sat Aug 28, 2021 6:56 pm
This is a tool used to cut strips from Formica (HPL) sheets. It may (or may not) work for cutting celluloid plastic. It slices strips without any "kerf" loss:
https://www.amazon.com/Virutex-C015L-Po ... B000071NUW
Most cabinet shops that do laminate work will have a few of these and may let you use it so you can try before you buy.
They do make large stationary cutters for production work:
https://www.specialtytools.com/shop-by- ... tters.html
And there are other various tools in between:
https://www.ebay.com/p/1324615033
PostPosted: Sun Aug 29, 2021 3:25 am
Maybe this'll give you some ideas, may well work fine with celluloid -
viewtopic.php?f=10117&t=19132
Made my own version, used for cutting purfling to height - viewtopic.php?f=10101&t=52216&p=687019&hilit=+viewtopic.php%3Ff%3D10117%26t%3D19132#p687019
These users thanked the author Colin North for the post: Dave Rickard (Sun Aug 29, 2021 6:37 am)
PostPosted: Sun Aug 29, 2021 9:46 am
If you want to move the tool rather than pull the material you could use a gramil (the same tool some use for cutting binding ledges) and line the material up with the edge of a cutting board.
How to make one:
https://www.youtube.com/watch?v=f821SaEm8E4
There are also simpler all wood designs.
Robbie O'Brien set up video:
https://www.youtube.com/watch?v=wL0eHnXPKU0
Users browsing this forum: CarlD and 27 guests
